- Jan 14, 2011
- Gillette, Wyo.
Based on di/dt you should have severe phase lag , not a total cancelling??
So , how they are wound and what they are wound with is a science unto itself ??
di/dt------change in current/change in time??
Ok Joe, the high frequendies are still there, just not in phase and at a much reduced level??
Not really Joe because water does not create magnetic fields that alter it's behavior.....trying to wrap head around this....
Does it take significantly more energy to amplify and transmit a 20KHZ signal compared to a 20HZ signal....
What is "L"...
At a high level, if you are driving into a purely resistive load and your transistors etc, are perfect devices then the answer is no. Loads are rarely if ever purely resistive and components are rarely perfect devices.
If the load looks like a resistor in parallel with a capacitor to ground then you will expend more energy driving into this load at higher frequencies (capacitive load).
If the load looks like a resistor in series with an inductor to ground then you will expend more energy driving into this load a lower frequencies (inductive load).
Generally speaking, the internal circuits of the amplifier appear capacitive in nature so the dissipation internal to the amp at higher frequencies is also higher. Sort of in the same way your truck engine has more frictional losses at higher RPMs and deliverable output horsepower and torque roll off.
Hope this helps and not hurts your understanding.
PS: I would not say significantly, but it is more.
The value of your inductor, like 1.1 milli-henry, that is inductance
Yes it does Joe...hence higher distortion at higher frequencies......
How does negative feedback correct for errors and why does it have to be "negative" feedback?? And what "errors"?
