That should do it..
What about the cap - it didn't fare too well. I should send some of our hardware to you for destructive testing.
That should do it..
I'm really good at it. I believe the cap was too close to the resistor, but I'm getting some funny numbers off my "Blue ESR " meter. In the mid 24uf paired and paralleled caps, I'm getting 765K on the Fluke in resistance mode and the ESR meter shows .01... Uf on the midcaps show right but why the extreme ohmage?
Why would a charged cap read more resistance?
So short all electros before ESR testing?
Shouldn't be any residual in a metalized poly anyway, should there??
The soldere was gone off the post the autotransfomer was tied to also, so there was quite a few issues here. The wire was loose to the touch on one side..
The root cause was too much f&^%$#@ power, but what to do about it. If I make this section bullet proof, what goes next. The resistors I'll go with something different but the caps may be my saving grace here....
Dennis, the big poly's I'm running in these are 24uf, 2 of them in parallel, 200 volters, bypassed by a 200 volt 2.2uf. The tweets are 2- 3.6uf 200 volters bypassed by a 200 volt 2.2 .
I'm not sure the caps are bad, they test good on the ESR meter, .01 or less and are spot on with the uf check section of the Fluke. The burnt one was too close to the resistor....
