laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,781 Pico fuses good? Rail fuses good? Bias trannies test good?
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,782 I just tested the socket on dbt with a test plug, it only needed a handful of volts. I have connected variac to mains, dbt to variac and amp to dbt
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,783 We tested them before, test picos again?
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,784 I dont remember testing bias transistors on backplane, which test method?
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,785 They are NPN, Pos on base, neg on Emitter, just checking for shorts right quick..
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,786 Diode test....
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,787 Bias transistors measure right backplane 843 +on pin 1 -on pin 3 1259 +on pin 1 -on pin 2 698 +on pin 2 -on pin 3 701 -on pin 1 +on pin 2 1360 -on pin 1 +on pin 3 1803 -on pin 2 +on pin 3 Left backplane is around the same
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,788 Bring it up slowly....
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,789 Picos, rail fuses and bias transistors all good
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,790 Ok 20 volts at a time. Relays click around 120v right?
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,791 And if the bulb goes bright, shut it down?
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,792 Relays click around 60 to 80 rail voltage....it'll get bright as caps charge, bring it up slowly in small steps, the bulb should dim as caps charge...
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,793 The meters moved around and pegged for a second 20 to 40 volts. I got up to 80 volts and still no bulb glowing??
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,794 Bulb should glow as caps charge...relays click?
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,795 No i stopped at 80, try again and go further?
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,796 Up to 100 bulb glowing very dim
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,797 No...try and figure why the bulb is not glowing.
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,798 Ahhh....it is glowing. OK, check DC offset on input of DC protect board...
derek92994 Veteran and General Yakker Joined May 1, 2013 Messages 7,679 Location Australia Tagline Oxygen Free Dec 3, 2021 #1,799 140 volts bulb dim no relay click
laatsch55 Administrator, Chief Negotiator Staff member Joined Jan 14, 2011 Messages 75,837 Location Gillette, Wyo. Tagline Halfbiass...Electron Herder and Backass Woof Dec 3, 2021 #1,800 You go to 240 right?
