DBT needs small clamps on the positive and negative right?
Dim Bulb Tester....100 watt bulb in a light fixture wired so the bulb is in series with the ac outlet built in the tester...
Like so...ac outlet for variac, and then amp after done with variac..
Gathering supplies for dim bulb tester, bulbs are hard to find, got one on order. Just need dual power socket with switch and sil pads. Got a couple of outputs on order from mouser. There will be a wait on parts, just have to be patient. Some good reference material there :evil4:
Outputs in, boards cleaned, just ran thru some testing of outputs soldered in with Lee. 384EFEB7-6EAE-479F-9F56-7D8995D54CE7.jpegCCAFDE47-2245-47F9-9EE3-7F0A1C3A5C16.jpeg8E86E30D-6F12-45D5-A8DD-0E9ACE21883C.jpeg
I have questions, DBT, i use the switch to turn it on and off, but it is not a bypass switch to bypass the bulb.
Active goes thru switch then thru bulb positive to negative then that goes to active on power socket. Negative and earth go straight to socket. Good?
Yes, one leg goes thru the light to the amp, other leg from amp goes to the other AC in ...., so basically you have all the current going through the bulb filiment, the more current, the brighter the bulb. Feed the DBT with the Variac..
Dbt plugs into variac then amp plugs into dbt socket?
Will have a cig and post pics. But first, there is some debris down the bottom of the chassis, use vac to suck it out?
