Ahhhh...check bias, set meter scale to millivolts..
Wonderful. Power down, let caps discharge, plug directly into wall, listen for relay clicks, let idle for 5 minutes, set bias to 375...
You are checkin bias between test point 2 (bias +) and test point 3 (out) correct?
The meters peg for a split second on power up before relay clicks. This does not seem normal?
I measured bias using positive in yellow bias L point and negative on black ground point. Same for right channel
Ok some confusion, i did that all on control board, forgive my memory, could not remember bias checking procedure
Thank you Lee. Should I run my spare speakers for a while or do you think she is safe?
