Yes Joe, the bias trannies are wired right.,....here we go,,,
With rail voltage at 103.7, bias dialed right in and very good offset numbers....a very uneventful first power up...
Got a lot of stuff to move over to the rack to put it on the horns. And , gonna need the variac to run power to the DCP.....
Wishing you luck Lee, I bet it all works out fine. So you are emulating 120 volts to 240 volts?
Hey look at this Lee, I found an amplifier which tells you when its HALF BIASS, check this out :evil4:
And you me...fighting some high DC on the outputs right now. Must have a whisker somewhere. When I tried to put it on the horns the DCP wouldn't release. 100 volts DC on the outs. Chasing it now..Lot of voltage, no current..
Missed the action yesterday!!! Dundee2 gonna have a WOPL :hello1:
once lee gets it right we can see if we can create a WOPL tidal wave!!!
from one country to the nxt!
You got that right. So many parts and countless amounts of soldering it would be easy for something to go amiss, I'm sure its a fairly simple problem. Its the nature of the beast being an 'Electron Herder'.
Probably an errant cut lead or whisker from the twisted pair shield.....
