- Jan 14, 2011
- Gillette, Wyo.
just for shits and giggles...
I have 3 fully comp 400's with the revA backplane boards with electrolytic caps, they are 47uf 160 volt caps. Should they be removed?
Only 1 chassis ground on left board and no ground on the right board. Your amp is correctQuestion, why is there no lead going from bus bar to centre connector on right backplane but the left backplane has?
Yep, those caps will fk your world upSounds like it Mark..
They have been running for around 8 years with no problems. A 400 has 80 vdc rail voltage and the caps are rated for 160?Sounds like it Mark..
If you like.I have 3 fully comp 400's with the revA backplane boards with electrolytic caps, they are 47uf 160 volt caps. Should they be removed?
Got er on the Jamos??
