It doesn't get any better than what is in there. The electrolytics are just PS caps. Not audio path caps.
That's reassuring Joe. Very satisfied with the purchase.
Been doing research on these. Like Joe said, and Perry said a good while back, quality parts and construction, even though China manufactured. The bipolar transistors and dual FETs appear to be Japan made Toshiba. At least that's what all the genuine NOS replacements appear to be. Those big yellow film caps at the outputs, I've read say "Made in Mexico", haven't seen any info on brandThat's reassuring Joe. Very satisfied with the purchase.
How's your Acurus compare to your old PL preamp?
Thanks! Haven't seen that thread, it'll be a good read.George, here is the thread where Lee did the work to the 3600
https://forums.phxaudiotape.com/threads/jasons-phase-linear-p3600.5063/
Photos of the Acurus boards show double sided and plated through holes. Looks like a decent quality board. I appreciate the info on the big film caps.Those caps are from Mexico and do not have a brand name. But they are in all the Aragon and Accurus gear so they must sound “decent” but also inexpensive. Perhaps, their construction was directed by Mondial and whoever they were made them to spac? I’ve not seen them in any other gear from any maker.
But I’ll say that if you like the preamp, this specific cap is the one to “roll” to find your nirvana.
I swapped mine “blind” (deaf) in the D2A but haven’t listened yet. If I was more clever, I would have put some terminals on the (shitty) board to facilitate swapping… I presume the Accurus boards are also single sided and pads lift easily.
Was the guru's suggestion, forget his name but he's a member here. He did same to Lee's Acurus as well pretty sure.Bigger tranny???? 5 watts!!!
