K, Hole #11, purpler, emitter of Q12, left channel negative drive, driver...
K, Hole #12, negative(ground) ftom left channel signal in. Make sure only the negative wire and NO SHIELDING gets soldered here. The shielding is attached at the copper plate and that should be the only connection for it.
Need some clarification again. Isn't it the shield that's the negative (ground) from left channel signal in and it's the centre conductor that connects to the board?
And, that signal in lead actually comes from the volume pot?
I may have screwed you up on this earlier come to think of it.....At the copper plate the signal ground and the shield should be soldered together on the copper plate. And only the ground wire to the board. Take a pic of the pots right quick...
Scrath that. That's hpow we do the White oak board. The shield should be on the board in said #12 hole, signal positive in hole #13...
Both shield leads are connected to the copper plate.
Left channel signal pot.
Right channel pot.
yep, shield to #12, signal positive to #13....
Done and sorry for the delay. These connections took longer to make. Needed to improvise due to the large amount of shield material.
Ok, I have to get up early tomorrow Gary. On the right channel side of the board starting on the left, #1 is red, unfused B+ to the positive terminal of the power supply upper cap.
I'll run through the rest in the next post...
Done, but i have to drop this for now too.
I live in a condo building and an elderly neighbour lady apparently returned yesterday from a few days in the hospital. She is very confused and wandering the hall, trying to let herself in to different suites including mine.
I've got one of the strata council members with me and the two of us, will stay with her until son/daughter or someone can be contacted.
Can't let her be alone right now, I'm sure she's very scared.
Will post again in the morning,
#2---white/ green/black stripe....collector bus bar positive drive right channel..
#3----red, collector, bias transistor, Q6 right channelk..
#4---blue, base of Q11, right channel
#5---Black, base of bias transistor, Q6 right channel
#6----Brown, emitter Q13
#7, orange, collector bus bar, positive drive right channel
#8---Grey, collector Q12, negative drive, right channel
#9---White, chassis ground, middle of right 3 terminal strip..
#10---yellow, collector of Q14
#11----brown, emitter of bias transistor Q6, right
#12----Purple, base of Q12, negative drive, right channel
#13---signal ground, right
#14 signal positive , right...
We'll power up tomorrow if ya think it's ready...
You're a good man Gary, help the poor woman...
Up to and including #8 is done.
I stopped because for #9, the white chassis ground wire in this amp does not go to the centre lug of the right 3 terminal strip. It goes instead to the negative left speaker terminal. That terminal was connected to the copper plate by that thick wire which I snipped off as directed.
I can certainly remove the white wire from the negative speaker terminal and solder it to that centre lug but thought I'd wait for your say so.
In other words, neither that white wire or the negative speaker terminals are now connected to chassis ground.
Well, being you have to relocate it , take it to the star ground point between the big caps.
Sorry again for the dalay. I was not happy with the connection of the signal leads to the Normal/Direct switch so tore it apart and re-did it. Also had to dig out the gun to get the solder on the star ground bus bar to flow.
All wires are now connected to the board. Should I be optimistic and bolt it back in place?
In about an hour I have to leave for while. I told a cousin I would help her move stuff from her basement. Will be back about 4PM or 5PM for you.
Still in the field. Yeah, I want to be there for the power up. Leave the board where it is for now.
Wouldn't have it any other way. Should I mount the bias transistors at this point before powering up?
