- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
I don't think the 400 power supply is capable of that. What I know for sure is a stock 700 with a neutral tranny(100+/-DC rails) will do 736 per and up. With a hot tranny god only knows.
Now remember these are the absolute max ratings, I would not advertise them as continous. For that to happen we would have to add a few more outputs per side and 2-3 times mire heat sinking WITH FORCED AIR COOLING.
I was referring to the 315 doubled so 630 per side theoretically possible? Can a bigger tranny be used. I have a few monster sized ones in the garage. How about the big Drakes?
Heat is the real issue yes, especially with a 4 finner. I wondered about mounting two small computer fans on the top plate since that's the only place they would fit. I do have a 8" clip on fan on the back of the entertainment stand blowing directly on the WOPL when I feel like putting the gas to her though. Wish there was a 8 fin conversion plate of some sort. It's never gotten so hot that I can't touch the sinks but they have been pretty warm a few times
