Gibsonian's Cherry Pl 700 Ser I, soon to be a PLWO-1000
If Joe can get a 700 that quiet, I believe I can too. So the re-wire begins.....
With this many wires out of the way, it seemed appropriate to DEEP CLEAN where I couldn't get at before...
And George Bush is responsible FOR NONE of the above...
This is starting out very nice!! AC run almost done...
And kudos to fitz43, those Thomas and Betts cable ties are great, love em Doug!!
The wiring is done. This is the most deliberate re-wire I've done, and it really did not take that long--4 hours maybe...
The wire routing can make a huge difference and I like the tight twist you did.
THD & N measurements, along with Joe's quiet like church mouse 700-B. I thought I could get close to his figures, I did not expect to surpass them...
I was also loaded into 8 ohms, I believe the test environment was as close to his as I could get....
THD & N at 1000hz 8 ohm loads, I think I've accomplished something now!!
THD & N at 100 hz, 8 ohms,
Yep, I'm purty tickled with it Scott. When you can outquiet Joe, you've done something...
"Hey... Shouldn't you be at work??"
<iframe src="http://www.youtube.com/embed/p0xWLahk86I?feature=player_detailpage" allowfullscreen="" frameborder="0" height="360" width="640"></iframe>
And then my shoes started to squeak, and Cathy (the non-cooperative little b&^%$) will be put on the horns in short order!!!
WOPL 1000 back in da house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
