- Jan 14, 2011
- Gillette, Wyo.
Yeah Dennis, some pretty cool shit. And I can access said toys 24/7. Don't get no better than that.
Sweet looking. Yes, jealous of the shop you get to work in, for sure.
I like that you made them larger this time for increased cooling. For most people/applications, this eliminates the need for cooling fans at all. Looks way cool too.
Ey... Who is you?87-1/2 degree Mark. Done with a hand drill took awhile to get the right pressure and rotation speed to get em to come out smooth.
Gibsonian, I'm in Phoenix (az) dO YOU WANT THE CABBAGE CASE????
A new member, who care how we got him... I should have said 90 deg or 120 deg, I'm thinking of the angle from vertical but the tool bit nomenclature considers both sides of the hole, I just forgot. Yeah, I try to do chamfers on the drill press sometimes and it almost works better to do them by hand with a variable speed drill. Of course, you could just slap them down on the magnetic chuck and cut them on the Bridgeport, right? Ha!
Those copper fins of handmade heat holding hapiness should fetch $500-$600 I would think; there are lots of pre-1982 pennies in there.
For manual hole drilling I use an optical punch - this uses a magnifiying lens to line up the guide base. The magnifier is then pulled from the base and replaced by a punch. The punch is tapped with a small hammer and the accuracy is around 0.001" or so it is claimed. I beleive that is not far from reality.
