Ed Blackwood's Heatsinks Phase Linear 700B
#47
Yep, imagine having to spend all those hours around that woman to do all that drawing. That, to me, would be an exercise in frustration, unless.............
#48
Lee, if you end up with a short pair (shorter depth - sticking out the back) save them because I was thinking about silver soldering some 1/4" copper tubing up and down across the fins (would have a hose between each set for expansion movement, and routing the hose across to a computer box radiator and fan along with a small 12V pump I have laying around. For coolant I could use water or ethylene glycol.
ksrigg
Wise, Virginia
#53
Absolute perfection Lee. If you EVER make any more, you know who the Phase Linear OCD Freaks around here are. I know Mark wants a set... Hell, now I want a SOLID Copper PL. 700B or 400...I don't know if it would matter....Might as well be a 700 while I'm dreaming...How freaking beautiful.
#55
Finally figured out how to finish the 2nd bend in a repeatable way. 1-1/2" solid bar stock welded to a push frame at a 45 Deg angle. The die will be a 3/8" thick 2" angle iron. The angle will sit in a couple Vee blocks with the spine down. I have to machine the radius out of the angle and I'll be good to go, just ran out of time yesterday to finish it. The ring on the other end fits snug around the ram on our 150 ton vertical press. Should keep it straight.
#57
Gentlemen, WE HAVE REPEATABILITY!!!!!!! And---we have achieved the same radius as the break. had to mill the radius out of the angle iron as the grinder left an unacceptable radius........
#58
Then it was just a matter of lining things up squarely and mashing the copper into the angle. H ad to flatten the mating surface after the big squish but it behaved itself very well after that.....
NavLinear
#60
That is some pretty innovative thinking there - I'm impressed. I know that getting that second bend was a tough nut to crack. A work of art - you'll need some polish for those to keep them nice and shiney.
I must admit that I like the big ass tools you have to work with.
