And the REAL reason behind all this???????? Besides seeing if I can actually do it--------------How quiet can they get. Signal to noise ratio. With a mono bloc-- no crosstalk, zero, zilch, nada. That removes that variable from the equation. So then we are left with , #1--Topology, the single most responsible factor to noise. #2-- Component selection, hard to be quiet with semi-conductors of certain ilk shouting all the time, #3 Layout and Construction Technique, we have some control over this area, which is what this little experiment is all about.
