phase linear 400
My two cents:
When I’m building up harnesses, I make up lose zip tie rings and feed each wire in, but don’t tighten the ties until everything is in place.
Seems to work well for me. But I haven’t built one of these amps.
The big one...page 37-38
i just went back...this file you just sent was not in the original 34 documents you sent....there was one similar but did not have the +-2 on the end of the file name....thats why i was having trouble ....sorry about the confusion...and i appreciate your help....
I am constantly updating documentation Gene. Eventually each document will have as many pages as this post does...
well, done for today....
i have a few pics for you all...
tomorrow i will take the pinout diagram and double check the wiring...
i only have one thing bothering me...
i had a 5 or 6 inch orange on pad 5....joe called it out....
when i was wiring i discovered that was not the correct place....
where does that wire go??/
i will have to go back through the assembly procedure to find it...
i dont trust that i have all of the wiring there....
i do believe what is there is correct....
any comments or observations is greatly appreciated...
thanks to all...
today is our anniversary....maria and i are entering our 6th hear of our relationship....
we had chatted on the internet several months before we met....
she never left....we have been together since that day....
she is a great mate for me....she can put up with my personality....
not an easy chore....just ask my ex....lololol
Gene, looking at the photos on a big desktop monitor while typing on the phone.
1. The yellow wires at the top are output wires that eventually feed the speakers jacks. These "fly" across open space between the backplanes and control board and must be kept separate and away from each other and other wires. No zip ties on these, they fly by themselves.
2. Your running the LED board AC wires down under the DC wires. A better way is to run them is up, not down. AC at top, DC at bottom. Check out the photo.
3. Going to post this and look some more at your photos
thank you....
easily redone ...
i understand...
seperating outs will reduce xtalk???
thank you so much for the photo...
that helps a lot...
phase linear wasnt this careful it seems...
dont worry...have plenty of wire and cable ties...
i.appreciate your eyes...and wisdom....
wonder if others are paying attention ..
shielded coax would eleminate that???
Gene, the grounds to the DCP (all three) usually run across the bottom.
Coax for the flying yellow output wires? This is a question I have asked Joe. He says leave them flying and yellow, away from the boards and other wires.
That black wire your using for "AC input from transformer" for the DCP should be red if you have the wire, and continue to run across the top of the right backplane, then down to the connection on the DCP.
