700/1 “Tim” WOPL driver board
AngrySailor
---not quite right
The diodes around those, the low voltage test points in the middle od the board. Rail fuses ok?
I annihilated the rail fuse on the right channel + rail when I slipped with the probe. The fuses are all ok now that’s when I smoked the bias resistors. I’m not real close to being up yet either, still got some reassembling to do.
AngrySailor
---not quite right
Fug... I forgot to solder the negative rail supply wire before I put the back plane in... this gonna be tight... F23AFF1A-7428-4379-828A-1C5A55364AD3.jpeg
AngrySailor
---not quite right
Ok I think I’m ready to try a bring up. Got stuff taped off like the 6v supply and the meter wiring. No DCP installed rn, speaker outputs taped off, RCA 401’s and one row of XPL909’s installed. Going to plug in the DBT and variac for this one... wish me luck!
AngrySailor
---not quite right
Right channel kept the bulb on, pulled the 410’s and the first row of 909’s. One of the drivers tested wonky swapped that out. I got drivers and one row of XPL909’s in now. Passes DBT, bias 260mv pot at minimum and responds to increasing. Time for another row!
AngrySailor
---not quite right
Cool, your getting really good at that!
Practice makes perfect:rolleyes: guess I’m getting lots! Hopefully got it licked. Might take a break for a bit maybe the night. Gotta put the DCP back in and connect the meters and light board too. Made a real brain fart there forgetting the negative rail supply, also got the wrong bias resistors... see how long these hold up!
You might be surprised....check offset too, when ya get the DCP back in...or you can check it now..
