Andrew, something to look for is the alignment of the heatsink and chassis holes. My 400 S1, 400 S2, and 700 Pro all have the same machining error at the far right bottom output transistor location. This is easily fixed. Perhaps this is the source of your issue when snugging up the outputs. Below is a photo from my 700 Build thread. Look closely at the photo for the alignment mismatch that trashes the original socket and makes installing the WOAD backplane stepped washers a no go. Don't know if the 700 S1 suffers the same machining error, but needs looked at.
