- Jan 14, 2011
- Gillette, Wyo.
I have a boxful in the garage...I'll dig em out tonight...I think I have some that will work .
Have to point out that the effectivity of your capacitor bank will be substantially reduced by in line connectors and wire length both of which are ohmic and inductive in nature. You will get DC performance and very low frequency performance but will rapidly lose any ability to reduce higher frequency content by outboarding. The amp will run longer after you turn it off but there is probably a DC protect installed which will ruin that experience for you too.
Ok, so shortest possible wires, no connectors.
Anything else that I can do within the capacitor box or within the amp to combat the effect, or that's it?
