700 RCA Grounding
Any benefit either way to use the "normal/ direct" switch ckt or would you delete it all together ?
The coax shield is the ground Im referring to ... The 220K resistors are shown on the white oaks "single point ground scheme"
I don't use the copper strip or any of that stuff. The direct switch is omitted (still in place, not connected).
Paradigm Signature S8's ...... Thinking this weekend or maybe tomorrow I will pull it apart again and post some pics ? and hope for a revelation !
Thanks for the input tonight ... I will post and update ....
Cheers
I think you were going to add some pics???
Ok Thank you ! Im gonna' pull things apart this weekend and get at it .....
Thanks for all your input .....
If I remember correctly, this would be for a partial upgrade. I build total WOPL amps and much of that is not installed for a complete upgrade with a DCP
Normal mode kicks a 1uf cap in series with the input, stripping any DC that may be in the signal from the source...Direct bypasses this cap..
That wiring diagram from 2013 does not relate to how this amp is REALLY wired. Just as an example, it shows rail power from the bulk caps to the control board. That is not how the amp is wired.
also, it does not show star ground going from the left back plane center hole with 3 ground wires going to the DCP, the 1 ground wire going from the same place to the bulk caps copper strip, and the 2 ground wires going from the copper strip to the left channel ground points, nor the 2 ground wires from the right channel back plane to the star ground point in the center of the Left channel back plane, nor the ground wire going from the star ground point in the center of the left channel back plane to the light board. If you wired your amp according to that drawing, it is wrong.
Is there a complete and up to date schematic or drawing floating around that lays out all the grounding tricks ?
I originally did the WOPL 4 years ago.... and it didn't seem that bad. I have now ventured into using a DSP and working on a tri amp setup.
As I was moving amps in and out I discovered that my currently stock 400 has way less hiss that the wopl 700B ....swapped out a crown xls 202 and same deal , both amps less no load noise than the 700.... I only came across that drawing recently , that has made me think !. .Hmmmm
I did or at least tried to follow the White Oaks instruction that were sent out at the time... Something is a miss ... Do I have a ground where it isn't needed... Missing one ? Dunno! Hopefully someone has a schematic or drawing I can look over .... ;)
I appreciate your wanting to do it right. You can search this forum and get much useful info on the subject.
Joe posted in this thread some years ago about star grounding.
https://forums.phxaudiotape.com/threads/zachs-700b-thread.3477/page-9#post-62249
He also produced the attached image of circuit without DCP
I think you have been given some better info within this thread on the subject as well. Please to do your own searching on the subject
Thanks for jumping in .. I posted that same schematic and the consensus is that it is incorrect....
I just opened the link you posted . AWESOME ! Thank you but do we have this kind of clarification when using the backplane boards also ?
Those 2 schematics of the ground scheme are deceiving. I would not use them for a 700B/II COMPLETLY WOPL'D AMP........ They may work for a partial wopl but not for one with a complete back plane kit, a complete control board kit, and a DCP from Wattsabundant.
Those schematics look like a 700 with a control board upgrade only.
IF, it was also back planes, it would show the ground point from where EVERYTHING gets connected (the center post for the left channel back plane......) When I build a WOPL, I have probably 7 ground wires which attach to the left channel center hole mounting point. There are a thousand pics here in the WOPL section showing that ground scheme. You gotta LOOK!
The ONLY grounds you should have are seen here on the left channel back plane. 3 for the DCP, 2 for the right channel back plane, 1 for the bulk cap ground strap, and 1 for the light board which can go to the strap or the star. the direct switch should be eliminated, and the copper crap and all that junk for the zoebel up in the right corner should all be gone.
if you are not running a WattsAbundant DCP, get rid of what you are running, and spend the $99.
It's well worth is, built like a tank, and is pretty much made to run with the WOPL.... Anything else is just junk..... This takes all the guess work out of the wiring since WA show show to wire it with a WOPL........
NUFF SAID
Perry I don't do that.. when did it become the standard? I'm thinking when the mono rev G came out?
I run all to the cap buss bar, except the one single ground to that left hand tie point. Must have been a revision since me last build, which has been a good while..
We need Sir Joe here to clear some cornfusing up..
NUFF SAID
+1... Lee didn't you have one trip and when it did, it really did some smoking on the traces of the DCP - basically sacrificing it but hey that's a shitload better than having to replace entire banks of outputs.
Also guys think about the instantaneous current through the relay contacts just prior to them disengaging, when a failure happens. Running a relay rated at 2 amps is likely going to fuse em, and here comes the 100+ volts right through to yer speaks.
Hmmm...... I'm sure I read that only ONE wire should run to chassis ground as Jbeckva said....
Joe ? Help ! :hello2:
