And, you can buy it assembled if Stevie is busy......
The WattsAbundant DCP is a professional grade piece.
Here's a picture of what I used for output protection
Your are right.That relay looks a little light for a WOPL.
I was curious to know if the group typically omits the gain pots from the rca's to the white oaks boards ... possibly I have too much gain causing the hiss / hum ?
The left and right "volume" controls ?
The left and right "volume" controls ? Not so much volume but Gain... Isn't that correct ?
Sorry , That's my point....They are bypassed ....The RCA's go directly to the boards not through the pots....
So there isn't any attenuation for the input signal ... essentially full blast ....
In the initial WOPL build I omitted them so unfortunately I can't say To your post , If the hiss is there with them in and no difference out
That would just about guarantee they were not the issue... At this point I don't have that comparison ....
A Question : in an earlier post you put up a picture of your RCA wiring , no 220K resistors from signal to the "insulated" ground ?
