mattoe
Any benefit either way to use the "normal/ direct" switch ckt or would you delete it all together ?
The coax shield is the ground Im referring to ... The 220K resistors are shown on the white oaks "single point ground scheme"
Paradigm Signature S8's ...... Thinking this weekend or maybe tomorrow I will pull it apart again and post some pics ? and hope for a revelation !
Thanks for the input tonight ... I will post and update ....
Cheers
Ok Thank you ! Im gonna' pull things apart this weekend and get at it .....
Thanks for all your input .....
Is there a complete and up to date schematic or drawing floating around that lays out all the grounding tricks ?
The ONLY grounds you should have are seen here on the left channel back plane. 3 for the DCP, 2 for the right channel back plane, 1 for the bulk cap ground strap, and 1 for the light board which can go to the strap or the star. the direct switch should be eliminated, and the copper crap and all that junk for the zoebel up in the right corner should all be gone.
if you are not running a WattsAbundant DCP, get rid of what you are running, and spend the $99.
It's well worth is, built like a tank, and is pretty much made to run with the WOPL.... Anything else is just junk..... This takes all the guess work out of the wiring since WA show show to wire it with a WOPL........
NUFF SAID
