I am going to order boards for my new PL amp design soon. I need 15 for my heard.
Preliminary Specs (Will be finalized when PCB's come in and testing begins)
- 100kHz power bandwidth (I don't recommend trying to get 350 Watts out at 100kHz, but it should do it, in theory)
- Slew rate - 37 V/us (Calculated. In reality, closer to 33 V/us probably)
- >100dB signal to noise
- THD+N at 20kHz <0.002% at 350 Watts/8 Ohm
- 1 Watt frequency response - 0.5Hz ~ 200kHz
Low distortion and slew rate are not everything and the design will be tweaked for sound quality and stability as well. To my ears, if an amp is "too fast" (high slew rate), it sound cold and clinical (not warm/musical). However, since we all hear differently, this design can be easily manipulated for your listening preference(s) within reasonable limits.
Let me know if you want to participate in the PCB order, so I can get an order quantity going. It looks like unstuffed PCB's will be $64 shipped in the contiguous US.
Except for some capacitor values/types, the "amp control board" design is very forgiving and parts selection is not too critical. The drivers and outputs for a full comp version should still use MJ15024/25 or MJ21195/96 transistors.
Board features will include:
- FR-4 epoxy glass board
- Top and bottom solder mask
- Top silk printing (white)
- RoHS compliant
- Double-sided, plated through holes
