Russ' 700B Wopl
I put the IEC plug in this way in the stock chassis. Joes has so much more room to work in.
I put the fuse into the power cord hole and cut out the fuse hole for the plug. It fits. With Joes case it's almost like I must have something out there is to much empty space. Amazing what a 1/4 inch here and there will do.
Especially on the height to get clearance for the backplanes...
New chassis mated to the transformer...
New BR , bypassed...
AC wiring done. I found some nice #14 ,105degree, machine tool wire, just perfect for what we need on the AC side.,..The IEC jack and thermoswitches, AND the transformer terminal strip have holes big enough for #14....
Backplanes in, time to wire....
Caps and BABB in......
Building the DC protect right now...
DCP done....
Rev "E" board...
Another hour and we'll have it...
Done....
Separating the pot wiring fom the meter wiring and dressing them up...
Thanks Joe....relieved is more like it. I've had it since October.....If I ever get a few hours it'll get done...
Supposed to be 70 degrees here today. Outside cleaning heatsinks today.....
Heatsinks and outputs....
3 out of the 4 heatsinks went ok, then the 4th.....had to relieve one set of out holes, were into a D drill already...looks like I'll have to slot this one....
Got em coaxed in there.....
