grapplesaw
Vancouver
That is a symptom, not the cause. You need to find the cause. What is the op amp doing? Is its output sitting at the +15 extreme? Is the class A NPN transistor any good or is it roached?
Thanks Joe
you are correct as usual - it is a symptom.
So I thought about it over last night and unconnected the two fly back diodes on the backplane. No change. I bypassed the E and C on the bias transistor and disconnected the B wire. Bias now ok.
Jumped the fly back diodes back to the circuit , all ok. Reconnected the black B wire on the bias transistor, all ok. Removed the bypass jumper on the C and E bias transistor, all ok.
Go figure!!! Did nothing and works, what gremlin remains , we will see
powerd to 240 volts across the two rails
.5 mv offset both channels
.10 mv bias offset both channel, no change when adjusting 1k resistor. No drivers installed.
30.25 volt regulated steady.
Stable for 30 minutes.
Time to reinstall the right protection and recheck. Then resold we fly back diodes.
If all good I will install drivers.
grapplesaw
Vancouver
The only cap I did not replace while trouble shooting was the 47uf 100 volt which is part of that bias circuit
That cap is not part of the bias circuit Glen. It is a bootstrap boost for the upper half of the amp circuit to ensure it is not starved for base drive current on the upper half cycle.
Here is the circuit for full comp
Hi Glen
The resolution on your markup photos is pretty low. Any way you can put up one that can be read when you zoom in?
It looks like you added miller caps to the 2N5416 and 2N3439. Not sure where that came from? What value did you put there? I also see a note about jumpering the 22 ohm resistor in the collector leg of each of those as well. Is the a reason why?
grapplesaw
Vancouver
Hi Glen
Joe the Miller caps are not present as of now. I plan on using 47pf silver mica caps. This was added per the service bulletin pictured.
The resistor is removed and jumper added. This is in the path shown in the full comp segmatic pictured. The other components are also removed as crossed out in my segmatic not on the phase linear segmatic attached. I have a photo of full comp board attached and I do not see this resistor.
You will note the correction in the reversing the E and C on the 2n5416 on my segmatic. This is incorrect on the phase linear comp one. This is also shown in the 2nd attached service bulletin.
The Phase Linear Comp schematic looks correct to me Glen with respect to the emitter-collector orientations.
grapplesaw
Vancouver
I have all those Glen, I was looking for a high res photo of the schematic you marked up in the earlier post #182
Hi had problem getting high res photo loaded
please look again at original post
the phase linear comp drawing I believe is incorrect as per the service bulletin the Violet wire moves from collector to Emiter. I hope this is correct or I have to change back
the back plane also does not show the new B- fused supply to the 2n5416
