grapplesaw
Vancouver
Need some help
so I spent to day checking and double checking everything
Bias problem was easy and fast one end of 10 ohm resistor not soldered.
So so I powered up slowly but as I did I get about 1/4 rail power as B + offset on the outputs with with or without any drivers. I was starting with the first row only. I desoldered the entire right side control board without change only fuses on. I only went to 20 volts across rails. Both legs equal voltage to ground so think power supply ok
I could just just take it up and see but why the offset so great.
What damage can happen if I take it up to full power?
Do I need second row to get offset in line?
Is there excessive B+ coming from the black/white/green connected to the 47 if 100 volt cap which is connected to the B+ board supply?
I know the old stock boards didn't come into regulation till about 60 rail volts. Can't say for sure on the PL 36 board though...
grapplesaw
Vancouver
Time to check in
after many hours of checking and rechecking I have solved my offset problem
After reworking the input RCA plugs and isolating them from the chassis I was left with the the ground open for both channels thus creating a full rail voltage offset.
Anyway i I now known exactly how a Pl36/32 control board functions, but cannot tell you why the values are what they are for the components
start to to put it back together tomorrow
grapplesaw
Vancouver
Time to get some input from everyone
need help with right channel bias fault full rail positive across 10 ohm resistor in backplane
no pre driver or driver installed in back plane
Dc offset 118 mv left 58 mv right
control board
right channel
all transistors replaced with checked good ones , output 101 and 105 new
all caps on right new
all diodes checked ,
protection circuit removed from circuit
resistance over brown and black connector correct at 1.6k
bypassed red and brown tranny trams black removed from board has same result.
Black tranny connection point on board voltage = full rail positive left is -11 volt
bias measurement over 10 ohm resistor full rail positive
left bias .55 mv
dc offset 118 mv
rail voltage 80 volts and 120 volt no reading change with either voltage
not sure what to do
one channel good enough to load drivers
want to get rid of bias over voltage in right first.
Any ideas please post
grapplesaw
Vancouver
This is the problem area
D101 lifted from board
all parts good
excesive voltage at connection 10 circled on left of the 2n3403 transistor
grapplesaw
Vancouver
All resistors in spec? VR good?
Both channel resistors equal and in spec
new caps with silver mica in lower pf caps. Same readings before and after changing. Double checked aluminum cap polarity
Swapped out q106 40412 - no change
VR 15 volts both + and -
I even changed them out as well just to cross that off
only one channel with problem
all wiring checked about 50 times.
Problem on on board as I unhooked blue and black/ white/ green and no reading problem on backplane after that
all parts good
A debug hint to let you find bias problem areas is to short C-E of the bias transistor (4 to 12 on your schematic) with a short jumper tacked in. The amp will work fine in this mode, will just have more crossover distortion than with the bias transistor not shorted.
Joe, when you short C-E does it represent full gain of the Bias Tranny or no gain, or neither?
So it will eliminate the bias tranny as the source of trouble, if shorting it cures the offset problem?
grapplesaw
Vancouver
Hi Lee
It represents a transistor with huge beta (gain) and with an ability to saturate at near zero volts Vce
My thinking is Shorting C and E. Should create an equal output from both pre drivers and show none or very little Bias voltage
grapplesaw
Vancouver
I will remove the Black / white / green wire and see if it is back feeding the circuit
there is no continuity from collector and emiter with power off on backplate as well there is no offset between the positive and negative collecters
