LarryD;17732 I missed the decimal. It was on the very small resistors where the wires from the board enter! [/QUOTE said:I guess you better point that one out too.....
Larry, I don't want you to worry about the driver board..I want you to do what I ask so we can figure out if there are any problems with the back wall or power supply. I will then send you a complete set of outputs and an assembled White Oak Rev A driver board. You will then follow very explicit step by step instructions to desolder the old board and install the new board. The board is one of 4 boards that were built and sent to me as a gift from Dr. Lucitt when he thinned his herd. They did not cost me anything nor will it cost you anything. I have some band new MJ 21194's which are perfect for the 400. I don't use those in 700's so you can have them too. But to do this you must listen to me and do only what I suggest and when I suggest it. I Don't Believe At your present skill level you can troubleshoot the board and repair it. I do believe you can change one out with help.
These boards are also complete with the Phoenix connectors so no soldering is needed to install them, and a wiring mistake can be spotted abd changed without desoldering and resoldering....
A thread like this is exactly why I don't mess with electronics
<iframe width="560" height="315" src="https://www.youtube.com/embed/_VrFV5r8cs0" frameBorder="0" allowfullscreen=""></iframe>
Ok Lee, Understood! You are right, I need to learn to walk before I can run. And the 16.57 came from the four green brown and silver striped resistors. Here is the pic. And I would like to say thank you very much for the gift, that is simply awesome! but mostly for putting up with me. And I noticed that the power supply was very loose on it's mount. I snugged it up with equal torque but did not over
tighten.
Here's a link to a good AK thread on testing transistors. FYI - The type of transistors you're testing are Bipolar Junction Transistor (BJT). The output transistors for a semi complementary system are all NPN BJTs.
http://www.audiokarma.org/forums/index.php?threads/bipolar-junction-transistor-testing-basics.43186/
There's a lot of information available on the web that can help. Understanding semiconductors you should begin with diodes as they are a stepping stone before transistors.
