Need help to repair two phase 400 amps
#90
They are a 40 year old output, with a much less robust "safe-operating-area" than more modern devices...
LarryD
Paradise, Ca
Does anyone make a higher end replacement? and will 909's be ok to change out? And are the seal pats ok to reuse? I also read that the grease was a better option?
#96
The 66456's are good. The outputs are not shorted. We don't know if they are all good though. You were blowing fuses correct?
Were the fuse burns a simple break in the element, or was the inside of the glass blackened?
