Yep. You're still back on the pre-Threshold 2 build.
If you're eager to move forward and don't want to wait for the Windows Update route,
grab a clean USB thumb drive 8 GB or bigger and download the Windows 10 Media Creation tool from Microsoft.
Easily Googled.
Create the installation for another computer when it asks,
then when done, simply run the setup on the thumb drive from within Windows.
Works like a charm ...
I attempted the Win 10 Media Creation but it failed saying it couldn't find any USB on the device.
First go was with a Sandisk 8G, Google gave some posts that Sandisk and the Media Creation had difficulties.
Tried again with a 8G no-name Chinese novelty USB stick. Same error.
I'll wait for the update to come around.
I just got another reminder to upgrade to 10 on one machine.
Do you want to upgrade now? Do you want to upgrade later?
I clicked on "upgrade later". It starts downloading Win 10. There is a button in the dialog box that says "stop download"
I click it(multiple times) and the download continues, it doesn't stop. The download progress bar is now at about 80% and it says preparing for installation. The downloading finishes and I get a dialog box saying "Great, lets continue"
I declined the Terms of Service to stop the madness. They are determined to push this on people.
Similar here over the weekend. I finally just gave in and did it. It took about 4 reboots to get all the favorites back. It is only supposed to take 1 but I suppose they are still working through things.
So far, no real complaints. I don't like edge because I cannot have 6 tabs as my home tabs (this is a relatively frequent complaint about Edge, otherwise it is a good browser, fast). Back to IE11.
Said just screw it and hit ok for the Windows 10 upgrade finally. Other then having to log back into the computer after I leave it alone for awhile, I notice no difference. Web is faster in use, just minor little looks for stuff, everything runs right. So far so good, shut Corina down and enabled tracking protection
I did not accept default settings, just hit not at this time for everything then went in disabled Cortana and enabled Tracking protection. If I missed anything, LMK
