- Jan 14, 2011
- Gillette, Wyo.
Yes indeed, the key toolage!!
Looks like a good repair job. The new chassis will be a nice upgrade to a unit that had a hard lifeSome extensive work was done on this. New emitter resistors...chassis,reinforcement...
The chassis repair is first class I would guess it may have been dropped. The wiring looks good enough to reuse but if you are going to do it then then dot right!! "Lee's way"Not really Glen. Some very good work was done to it. It looks like all of it was preventative in nature. A lot of new wire, very well done. Somebody knew what they were doing.
I used the following my buildThere is actually #14 for rails and speaks....
I've run some of Navo's #12 from the BR to the caps, it does take some finneglin to get it in there...
I put the IEC plug in this way in the stock chassis. Joes has so much more room to work in.IEC plug. Joe did a heck of a job fitting that in thete.....
