- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
The chip I am using is a LM3914, which yeah if I floated pin 9 changes the "mode" to "dot mode".. basically the single traveling LED like the cylons LOL. This is definitely better - more color, more light.![]()
hmm, now you have me wondering. I should dig up a datasheet on the Series II power meter driver chip and see if it has a similar option. Maybe I can modify mine with small work. I can tell people it's an exclusive feature that came only on the Pro model or something.
UAA170 IC.. Doesn't look good - no option other than LED brightness.
D2 Yep, I have a sensitivity adjustment on the boards but I am seriously thinking of bringing that "outboard". Make it a variable sensitivity control instead of the 0/-20 "two option" switch.
Yep variable for sure would be great. Is there a way of adjusting how long the LEDs flash for?
Anywhoo.. here's the latest.. adding my own lil touch with the "color code" heheh.
Oh.......s..t....f...u....don't bring any coolrs to mind...well. Tan maybe...
UMBER???? Seriously??
