jaetee
- Jan 19, 2011
What's the matrix numbers in the deadwax of the Elvis? Beatles? I have minty true 1st pressings of both myself. The only way you can tell is by the inscriptions in the runout area of each record. If you got real 1st issues, congrats!
Things got moved around a bit and I couldn't easily get to the record. The numbers in the deadwax of the Elvis record look to read: 02 PP1282-17S but I should add that the "0" at the beginning is a guess, I can only see the top half of that character.
EDIT: did some research... and took a closer look. it appears the "0" is a G, so it would read "G2 PP1282-17S" and the other side reads "G2 PP1283-9S"
It seems I have this record here: http://collectorsfrenzy.com/gallery/150986819595.jpg
Which does not seem to be among the ones listed here: http://www.elvisrecords.us/lpm-1254-elvis-presley/
This appears to be (as well it should be) a very well documented record...
