- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
Post #953, pic #3, D2. It either a flux shadow or a wire whisker. Dennis could you check it out too?? 2nd output up from the bottom....
Ok, show me a pic of the rerouted black transformer wire...
Never mind D2, I scrolled up and saw it. Get that nut back on the cap hold down..
You've inspected, vacuumed, loooked, poked , prodded, made sure the power switch is not touching anything with its terminals?
No when it is...it runs real close to the light board if it's oriented certain ways.....
DO YOU HAVE A METER??
No, I want you to pull the 4-5 amp rail fuses, hook your meter to the bus bar with negative meter lead and turn the amp on and check plus and minus rail voltage. Do you have mini-grabbers on your test leads?? Post a pic of em...
To catch folks up, we had a fuse holder problem. Powered up fine with rail fuses out. +108DC, and - 108DC for the rails.....This ones gonna be a hottie....Rail fuses are now bck in and with the next power up we are prayin for DC relay clicks
OK D2 hit it!!
OH HELL YES!!!
