That looks good there D2. REMEMBER....after you get all the wires soldered in CHECK FOR SOLDER SPLASH, wire wiskers,etc and vacuum before you put the caps back in. Get the caps back in and tightened up and wired in. Top cap( or away from you) has the positive terminal toward the backwall. Bottom cap ( or the one closest to you ) has the negative terminal towards the back wall.
DO NOT POWER UP ANYTHING TILL I GET BACK AND HAVE A LOOK AT THE PICS OF PROGRESS.
Live long and prosper Grasshopper...gotta go..F*&^%$# oil spill...
