Walk away and come back to it later.
I'm off to get some milk….<script type="text/javascript" src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/6f136b72/background/helpers/prefilterHelper.js"></script>
The wire is obviously not fitting now because of a tiny bit of solder, I have tried to make it larger by melting the solder and sucking it away with the solder sucker. Its not working, the wire won't fit now. Does the wire have to go in the hole? Why can't it be simply soldered to the terminal?
