- Jan 14, 2011
- Gillette, Wyo.
Not for the solder he's got on there now BD.
D2, I gotta be up at 5AM. It is now midnight. Finish those 2 solder joints up and we'll finish up tomorrow Bud. BD can get ya through these 2 joints. BD, when he gose with the new 60/40 he can tone down that iron...
I have an air compressor to so can blow those metal bits away when we are done.
NO>NO>NO!!!!!!! Vacuum cleaner NEVER COMPRESSED AIR!!! We can not have anything go under those backplane boards!!!!
Ok cool, thanks for the help Lee. What time will you be on?
What time do you get up??
clean up that blob behind the top right terminal. suck that thing clean.<script type="text/javascript" src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/6f136b72/background/helpers/prefilterHelper.js"></script>
OK, I gotta go to the shop for awhile in the morning. I'll let ya know. Finish those 2 joints with the new solder. Do what BD suggested. Get a water wet rag and wipe your tip off and retin it. Then attack the joint. Nite..
Thats the hardest one and the scariest one because its so close to the component.
