Australia
Full Bias please :evil4:
Rough day for me, have not been feeling well, had a rest and not much better, gotta stick it out.
Australia
A friend of mine has suggested Passive pre-amp where the signal does not flow through a volume pot. I'll audition one sometime and see how it sounds.
Resistors also have noise.......the only thing that does not produce noise is a piece of wire with gain.....
Australia
Not much advantage then compared to conventional pre amp? Those passive things are quite expensive too.
Australia
Could plug the source directly into the WOPL and use the volume pots on the amp itself if I want to be as direct as possible source wise?
Yes you could. But remember, a good pot is almost invisible anyway. I have run CDP's straight to the WOPL's, with a good pre I would be hard pressed to tell a difference and doubt I could do it in a blind test....
I have to bring up the power supply on a variac and DBT after the big caps have discharged fully. It'll take out a 20 amp breaker if I dont.
<iframe width="480" height="276" src="//giphy.com/embed/z5Z3c9y8UzGko" frameBorder="0" allowfullscreen="" mozallowfullscreen="" webkitAllowFullScreen=""></iframe> :wink:
