P.L.F.
I love BIG amplifiers!
Hi Lee, it looks fantastic! :blob8::blob8::blob8:
What about rail voltage, also when loaded? And did you measure RMS power ratings? Anyway, started to compare 'before' and 'after' readings - just TWO COMPLETELY DIFFERENT WORLDS... WOPL rules!!!
NavLinear
You did a bang up job on this one Lee. It's good to see you back on the bench and to see those wonderful reports from the AP. Przem hit the nail on the head that the before and after results were dramatically different.
P.L.F.
Here they are - Yamaha S 4115H series I, see the pics encl. (http://www2.yamaha.co.jp/manual/pdf/pa/english/speakers/S4115HE.pdf). [...]
As I said earlier, didn’t like the glass wool damping at all. So it was replaced with more sophisticated material - 75% sheep wool and 25% of polyester fiber. On the back wall I used 100% white sheep wool only with some pyramid shaped sound absorbing rubber foam (I know, a bit crazy - but it was an experiment and the damping stuff was given to me by a friend). Results? Well, these Yamaha are veeeeery loud speakers with their almost 102 decibel sensitivity. Bass was greatly improved, no doubt. Still I think, one can listen to that kind of setup not for a long time, unless risking deafness … :violent1:
So, thanks to Lee, I’m slowly getting ready for my WOPL1000 for further 'sound feasting’… :cool:
marcok
Milan Italy
Przem and all,
I have understood that in this forum most of you have high efficent speakers like KHorn and so on ( about 100 dB spl/mt )
powered by PL 400 or 700b ( not stock but WOPL )
To be honest I don't understand this amount of power .
At least I and my father have AR , Allison and Infinity ( 84-86 dB ) and so PL and Carver are the right solution .
Anyways I also understand that is fantastic to have a Ferrari or a Lamborghini and that this an hobby and we are
here for amusement .
It's only a my curiosity , because I 'm trying to understand your ideas about hi fi .
Ciao
Marco
Marco, more clean power means more headroom and less potential for distortion/clipping
marcok
Milan Italy
Northwinds ,
you are theoretically right , but at this point I presume you mainly listen to rock music and that in US the room sizes
are bigger than in Europe . I believe these are the main reasons . Do you confirm ?
Besides I and my father generally listen to classical music ( Bethoven , Mozart , Bach , etc. )
Anyways Phase Linear is always Phase Linear ( and Carver too ).
Ciao
Marco
P.L.F.
And you may not use all that power to face shaking emotions... For me what counts is dynamic range, large headroom and crispy sound with tightly controlled bass. Then what else you may need is a bottle of good whiskey ... :) the yamaha speakers are 120watt noise, 240watt program and 480watt peak. Good for a party - can almost blow a candle in one meter distance, not really hifi listening though... Having a noisy amp you could not bear high efficiency speakers, too much buzz on silent moments. Spent a lot of time to get rid of all kind of residual buzzing in my other PL700II... For real HIFI listening in long evenings my JBL's 5000Ti sound great to me... They are something like 92 db...
...and apart from psycho rock, hard rock of 70's/80's I do listen a lot of jazz too...
marcok
Milan Italy
Przem ,
I can adfirm that at my home ( and my father's home too ) the sound is great .
No hum , no buzz , etc. Not only , I had to attenuate the output of PL 4000 and C4000 ( ca 6dB ) to
to have good adjument of master volume .
Obviously I can't give you the evidence .
Conclusion : sound is a sensation and it's impossible to measure or evaluate.
Ciao
Marco
Ps: enjoy your WOPL 700 tailored by Lee ( very good job )
Marco, in my case I love to be able to replicate the concert experience in my basement...and I have this passion to vibrate my eyeballs ater a particularly bad day at work. And I can attest to the fact my tunebox has saved numerous lives that might have been at risk if not for the OVERWHELMING quality and intensity of my system at Mach9...
P.L.F.
Oh Yeeaah! :headbang:
Until having PL gears, in such moments, I used to go chopping wood with my 'fiskars lethal weapon'... Then once I went to play 'Whole Lotta Love' with pots at 11 o'clock and found myself in a completely different dimension... :happy2: Priceless feeling...
Marco, I listen to anything ranging from heavy metal to baroque organ music. My living room is 26' x 22'
You need that kind of power especially for baroque organ because you run out of amp awful quick. Who wants to hear a cathedral organ at conversation levels? Same goes for symphony orchestra pieces
marcok
Milan Italy
At this point I can't reply , because ( I repeat ) the sound is a sensation .
We could discuss about noise , THD, slew rate , dynamic range , damping factor etc , but
the right thing to do is that we should listen together to our gears at our home , but it's impossible .
Anyways let's enjoy our PLs.
Ciao
Marco
