When trying to drill holes in chassis' I use a transfer punch to start. The layout is critical when using countersunk screws like those needed in this IEC plug. The transfer punch leaves a shallow depression, but not really enough to go hogwild with a hand drill. So, I start with a 1/16" bit in a pin vise and deepen the starter hole a bit more to lessen the "bit walkin" that would really screw up this nice chassis....
Thanks Joe....any ideas for a bulkhead connector that would fit the old AC in hole??
For the 120 fan voltage.....how about an RCA jack???
Lee you don't want to make a widow maker...
Wire in a 6" long wire pigtail with female 5-15R on the end of it to plug the original fan plug into. Use the original Heyco clamp to strain relieve the pigtail into the chassis hole.
Think safety here.
