- Jan 14, 2011
- Gillette, Wyo.
And into 8 ohms, they both clipped around 505 again...
When the circuit is in play what does the scope trace look like?
Clipping, causing it to look more like a square wave than a sine wave.
I guess we would call that empirical evidence the protection circuit is not involved with the act of clipping....
Current starvation??
Both clipped at 387 into 4...
Times 2 (for the 4 ohm factor) = 774W
yes, it is measuring power onto 8 ohms. Haven't figured out how to change it yet. So the 378 at 4 ohms was really 750 plus....
Lee
You indicated earlier that the PS voltage was sagging to 79V when you were wailing on it at 4 ohms. Well your 55V RMS is 77.7V peak which is all she's got.
"Captain, I think you are going to need a bigger boat..."
