- Jan 14, 2011
- Gillette, Wyo.
When the circuit is in play what does the scope trace look like?
It's damn noisy, residual is 465 microvolts on one and 2.6 MILLIVOLTS on the other. THD & N is good, Signal to noise ratio is 30db on one channel and 80 on the other... 2.6 millivolts is a TON of residual noise, should have ben able to hear that buzz for a mile...
The protection circuit limits current X voltage = power dissipation in the power transistors.
It's similar to a power supply protection circuit that I discovered by accident a long time ago that measures the voltage X current in the transistor, but the difference is that this amplifier protection circuit measures the voltage X current in the load instead. This means that the operation of the amplifier protection circuit is not affected by relatively minor fluctuations in power supply voltage.
The amplifier protection circuit automatically reduces the current limit if there is too little voltage across the load, caused by the load resistance or impedance being too low.
It's operation much more similar to a power supply foldback current limiting circuit.
At 4 oms loads, it clips at 55volts....that equals 14 amps of current.....
At 8 ohms load it clips at 63 volts....that equals 8 amps current.......
Things are not linear...so there is a voltage component to the protection circuit??
And it is likely clipping in both cases from the influence of the protection circuit.
Have you tried lifting D9 and 10 on one channel?
Wow. I think I might understand this a bit. Huh. I guess the word protection means to protect even if in doing so it screws up other stuff. Am I right? Or should I just stay out of it lol
No Joe I have not....well it garner some needed info if I do?/
That nagging question eh?? You funny Joe. Yeah, 4 amp compared to 16, jeez. Ok , one more question. On your board did you up the SOA for the better outputs of today?
Yes slightly Lee...
