Jason's Phase Linear P3600
Got correct power supply voltages accross all op-amps, +14.2, -14.1 Missing some gain. Max out is 450mv, should be north of 2 volts..
Minimum input level for rated output is 150mv, I only had 40mv. Rated output is now 2.1 volts... Distortion sweep coming up...
Everything is groovy except for the bass response....it would be nice to have the FR curves match the amp. The amp will not do 10hz if the pre-amp won't....
NavLinear
What did the 3300 II do at the low end? If you could flatten our the bottom end that be would awsome. I'm assuming that's why you were asking about the cap value change.
FR curve...
Nav, Joe, or Jer, to fix this response I would have to take C106,206 to .68uf, correct?
First had to flip the schematic over, was getting a stiff neck :)
Yes C106 at least 0.33uF and C107 to 47uF with a 0.15uF film bypass across it as well.
Those appear to be the frequency response bottlenecks.
Ah Joe thanks!! I'll get right on that!! 22's to 47's with a bypass and thge .15 to a .33 could the .33 be mylar, may not have a .33 in poly.?
