 - Jan 14, 2011
 - Gillette, Wyo.
Just that quick...
			Minimum input level for rated output is 150mv, I only had 40mv. Rated output is now 2.1 volts... Distortion sweep coming up...
Everything is groovy except for the bass response....it would be nice to have the FR curves match the amp. The amp will not do 10hz if the pre-amp won't....
I've got the bypass caps accross pins 1,5 instead of 4, 8. For the first problem...
FR curve...
Nav, Joe, or Jer, to fix this response I would have to take C106,206 to .68uf, correct?
both of ya!! THD & N coming up. Things look great if we could get the low end fixed up. Yes Nav, that's the one.
Love ya ....both...
Did you swap out the caps? What was loading down the input voltage to the opamp?
Dyam, the PL700 power amp has better signal to noise than the pre does![]()
Ah Joe thanks!! I'll get right on that!! 22's to 47's with a bypass and thge .15 to a .33 could the .33 be mylar, may not have a .33 in poly.?
Uh........only 40mv input instaed of 150mv input...........dumas.........
You know I have some 1uf film caps.....
