- Mar 6, 2022
duly notedAbsolutely...
Selco OA-190-QC
Selco OA-190-QC
If you have a DCP then you can connect your meters to the Speaker output extensions on top of the circuit board. This means the meters are showing exactly what the speakers "see" and you will avoid the meters pegging on the ON transient and the OFF "thump", which will not hurt the meters but makes me cringe anyway.
Black = GroundHi again. After quite a delay caused by the need to reorder a replacement bias transistor that broke during the installation of the power transistors, we were able to install all of them and then put the new driver board in and wired it up. About the light/meter board wires: which one is which? Take a look. Thank you for your help.
View attachment 68193View attachment 68194
dont feel bad...i cut my bias transistors too short...and had to reorder too...Hi again. After quite a delay caused by the need to reorder a replacement bias transistor that broke during the installation of the power transistors, we were able to install all of them and then put the new driver board in and wired it up. About the light/meter board wires: which one is which? Take a look. Thank you for your help.
Yesdo you have wattsabundant protect board installed
Pictures of your wireup would help us help you. Pictures always help.Oh OK thanks for the advice. All of the transistors are already in, and are not shorting to the chassis. I think I should check them again, though, for bent pins or such.
the last 2 dcp boards i bought had a blue led...that lit when relay engaged...Are you hearing the DCP relay click? If it does click as it engages, that's a good sign. If it doesn't click, that's a bad sign of miss wiring or DC to the relay over the flying yellow output wires from the backplanes to the relay.
I've never brought a amp up to power without a Variac and DBT. Not sure what to look for without the Variac
