- Jan 14, 2011
- Gillette, Wyo.
Aw jeez....
Over the top of course Lee. Tee down to the thermal cutout switches...hOW YA GETTING EAST TO WEST WITH THE ac jOE?
wHOM PUT A QUARTER IN YOU TODAY??
Make sure you use the antique tack hammer for the job Dennis. You have to have the correct patina on the hammer for it to work properly![]()
Turn south just after the end of the right channel board and head south to the AC business.
All DC routes take the southern route and lay along the bottom of the chassis, underneath the board connect wires.
Outputs are short and sweet staying away from the AC bundle and laced together to get to the output posts.
It looks like I'll have to get a bigger vice also.![]()
When you are ready to install the boards, here is how you do it...
Ensure the 4 round spacer screws are in place but not tightened down. They should be able to move within the hole but not so loose that they are flopping around.
First put in all 48 of the shoulder washers...
Then get the boards all cleaned up, joined and ready to install...
Next position the board set over the round posts and the screw through the bias transistor strap and lower into place...
Next drop a 1/4" ID, thick washer on the upper round post screws, then put on a #6 flat washer and a 6-32 hex nut, finger tighten to put pressure on the board.
This will hold the boards into place and allow you to flip over and final position them...
Flip the chassis over and it should look like this with all 48 shoulders protruding equally through the chassis...
Put four 6-32 in the diagonal corners as shown to locate the boards in the proper position.
Tighten the round spacers in this position. This locks the location of the boards to the chassis...
Simple...
Beat me to it Joe..
Lee
I am going to add the recommendation to ream the holes in the 12 mounting screw locations from the original 0.234" (A drill) to 0.242" (C drill) The chassis and heat sink holes are line to line which should never be the case. PL did not do that on the PL400, they had the HS holes oversize and let the chassis control.
With the C drill, it is possible to line up all the bosses and have it drop into place. With the original size, it is impossible. Do the reaming on a drill press and use a sharp C drill.
These are what I've used to hold the boards in place before the heatsinks are added. I use 2 like you do, he same catty corner pattern. These bushings are deep enough to swallow the boss and being hard rubber have some "Squish".
Nav, the nylon screws faired very well, maybe a little melt on one...
OK, got a drill press. No way with the tolerance of your hardware is there enough wiggle room eh?
Lee
