- Mar 6, 2022
my favorite
I was a little confused when you went back to the dual pots, George. I also yanked the dual pots and went to the single gang design based on the work you documented several months ago.Going to clean and reassemble those old PL pots. After a lot of thought, think I'll use a single new Bourne's 100k pot in place of the original dual 50k balance pot, and go with one of those stepped two channel attenuators with the precision resistor array for the volume control. Been putting it off for a long time, but it's the way to go. May or may not keep the power switch. May even use one of the resistor array attenuators for balance. Need to see what's available.
Listening to The Walkabouts.
i would try to do something like that....i started to work on it when i had a replacement in hand...I never had the guts to dissemble these. Always sprayed DeoxIT and injected fader grease. Filthy inside. Green copper sulphate on the fader contacts.
Could probably clean with alcohol/Qtips, regrease, and be good again. But going to look at the links SupraMan posted.
The balance pot uses ring terminals, the volume/power pot uses bayonet. Might be a problem.
Balance pot above, volume pot below
As the father of two 20 something gorgeous girls, it's good to see her wear some clothes. But she needs to tie her shoelaces.
She needs a simpler, cleaner, less notes rendition of this song...Kinda busy and Over the Top........ Glad she had loose shoe laces to keep my attention.
One of my favorites too Fred, love the wailing guitar of Clapton.I love this song however it comes to me. High school.
Good chance the wailing guitar you enjoying is Duane Allman.One of my favorites too Fred, love the wailing guitar of Clapton.
