- Jan 14, 2011
- Gillette, Wyo.
Good industrial design is timeless..
Wow….just WOW, beautiful.Okay!
Long delayed update (Machine shop was slammed over the holidays) but my face plate is done! (well, machining is done- lots more to get to completion).
What do you guys think? As of now, I'm planning to fill all engraving with black lacquer, and the beveled edges of the copper will be polished, with the face being "brushed". Aluminum face will be "brushed" as well.
I have silver buttons for the four push buttons, but I also have black ones, with the top chamfer polished aluminum. Leaning that way now, but I'll mock it up and see how it looks.
I re-flowed all the SMDs and it's graveyard-quiet now. I need to address the pan pot, since there is no clear wiring diagram, but I guess I only have nine choices, so I should be able to get it...
The other copper plates are extras; well, the WP-2 one is for my headphone amp. Also Wyn's design, with a stepped attenuator it sounds... like nothing. Just how I like it. Since I am forced to use headphones or nothing these days, It's getting a lot of use and there is zero fatigue with it and tons of headroom (I bet it could drive speakers). I was considering one of the Krell KSA-5 headphone amps from eBay but no way.
Another update.
Again with the wrong relays… these are/were the same relay, just with bent legs for SM. I straightened them carefully and found:
They don’t fit.
After three failed attempts to get a fucking pair of relays, I MADE them fit.
View attachment 56216View attachment 56217
One side I got through the board; the other side is surface mount. I flowed enough solder to see it in the holes on the other side so, DONE.
This is going to be "High Performance"?
Gotta stick around for this.
Where's the KABOOM
I saw one of those tiny levels recently. But I have a good arm/cartridge set up and I don’t want to mess with that!
I have one floating around on the Rega anyway when it’s in use. I’m just going to mount it nicely so it doesn’t slide around and get caught under the dust cover…
I put Pennies on the counterweight of my JC Penney system! Deftly secured with electrical tape. Serious.
And I have to breathe too? Like I’ve got time for that!!!
