- Jan 14, 2011
- Gillette, Wyo.
How many sheets of Plywood did this take? And I notice that most people put veneer on. Is Veneer necessary?
I'm asking because veneer looks like an added expense which if you use a higher grade plywood that veneer could be eliminated. Are there too many screws that hold the panels together that Veneering would be the only way to eliminate those ugly screws? Could biscuit joinery be used on assembly versus screws?
I am assuming the bass bin is of a vented design, so there is not a lot of pressure inside the cab.
I have a pile of tongue and groove hardwood flooring left over from jobs; Brazilian cherry, oak (red and white select and quartersawn/rift cut). I would imagine this stuff would make some serious cabs for a project like this. It's a lot more expensive then plywood but I am wondering if there would be an added benefit of hardwood enclosures in terms of cab stability and added weight for dampening?
Got your tu-tu??
The bass bin IS NOT vented and MUST BE airtight....I have plain old plywood---unfinished--- cabs....
Mike. The back of the woofs are sealed.the fronts obviously are not. That's common to all k's and k-klones...
Yeah I understand what you are saying. Thats typical of any acoustic suspension speaker. A sealed cabinet.
But I always thought Paul Klipsch horn was open at the back and used the corner to extend the bass horn to extend
the lower freq. That why the placement in the corner..........hence corner horn. They are not sealed per say.
Here is a cut-a-way photo.
Looks complex with many internal dividers!
