- Jan 14, 2011
- Gillette, Wyo.
Yes, and the right exept for the white wire.
* sigh *
Such much for levity but I still think my diagnosis sounded cooler
All of the outputs, except two, on one side of this amp were bad. All on the other side were good. Replaced all of them on the bad side. Now I'm wondering if I should have done the same on the good side just for good measure. Thoughts?
They are RCA 410s, which I think Lee said are the good ones.
The outputs were all F PL909s.
When you said all but 2 were bad in one channel, you mean you had 10 bad transistors in total?
Sorry, all but two outputs in one channel were bad........in other words, 8 out of 10 tested bad in one channel. Replaced all 10 with new MJ21196 output drivers. [TABLE="class: no-border cartProdDetailcell, width: 0"]
<TBODY>[TR]
[TD]Mouser #:
[/TD]
[TD]863-MJ21196G
[/TD]
[/TR]
</TBODY>[/TABLE]
The 10 in the other channel all tested good and are still being used.
It is futile to resist.....
Let me show a little more of my ignorance about electronics.
I installed new output transistors in the left channel of this amp today. The right side already had new ones.
Do I need to recheck the bias now? Or is bias only affected by the transistors on the WO PL14_20 board?
