BMWR75
OK -- I pulled both of the new Q4s I had installed backwards and tested them. The one on the left side of the board was fine, the one on the right is shorted.
Did me installing the Q4s backwards cause R16 connected to the emitter of Q5 to smoke itself?
So, I installed a new MPSA92 in the right side Q4 position and put the left side MPSA92 back in too (both oriented correctly this time).
After doing that, redid the in circuit test results for Q5 on both sides of the board.
Right side of the board when looking at the component side (I am assuming this is the right channel)
Q5 base to emitter = 0.55 V forward bias and 0.83 reverse bias (this is the side connected to the smoked R16)
Q5 base to collector = 0.54 V forward bias and 0L reverse bias
Left side of board
Q5 base to emitter = 0.54 V forward bias and 0.82 reverse bias
Q5 base to collector = 0.53 V forward bias and 0L reverse bias
Left side of board
