i am not that expert on this, but why changing resistors at output?
can't you do something directly at the meters, where your problem actually is?
and, why don't you check levels at dolby chips, where it's more important that it's the right one?
nice solution for those heatsinks, as those transistors don't have a hole for the screw.
Hi Vince,
Dolby levels are as they should be. Adjusted with ANT test cassette, 245mV (varies 240-250mV) .
As we were talking before, 965 peaks little more that it should and I'm just irritated of that. I have solved that part by replacing R41 and R42 with 11K instead of 10K (as ANT told me to do so). There is no another way to deal with peak meters.
Next problem is that while signal is at 0db, output is 365mV instead of 400mV which can be adjusted by replacing R47 and R48 (100K) with something else. As I wrote earlier, it can be something around 110K.
Making at the moment a little pcb with resistors 100K + 4.7K + trimpot 10K which will give me variable resistor 104.7 - 114-7K. That way I will determine what value of that resistor I need. That's because I don't know how to calculate (formula).
Observe that whole solution can impact accuracy of calibration, but I have to test an see if this solution works.
